Bumpsteer in I-beam non ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2008, 09:25 PM
need strog32 chevy front doors
Last journal entry: Tbd
Having trouble understanding completely what it is.
In a traditional rod with a draglink that moving parallel back and forward along the chassis rail what is considered excessive bumpsteer and when is it not negative. Pictures would help me out too if ya got em
Old 10-17-2008, 11:06 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Generally speaking; all bumpsteer is bad on a street car. The car should only turn when you decide to move the steering wheel. With the steering system you have it can be difficult to eliminate all the bump steer. Visualize the steering link attached to the pitman arm when you are going straight down the road. When you hit a bump, the axle moves up, and unless the trailing arms that locate your axle are parallel to, and move in, the same arc as the steering link, you will get bump steer. So if your steering link is dramatically either longer or shorter than the trailing arms, unless you want to rework your steering or suspension, you got what you got.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 03:18 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
