bumpsteer / suspension design question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2006, 03:28 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
assuming a typical mcpherson strut front suspension on a unibody car:
say you have a front suspension thats designed so that the tie rod is @ the same level, length and angle as the lower control arm
is this better or worse for eliminating bumpsteer ? or would it have no effect ?
Old 08-30-2006, 05:54 AM
astroracer's Avatar
Bumpsteer is caused by a mis-match of the "inner" tierod point to the theoretical centerline struck through the upper and lower a-arm pivots. Even though a strut suspension doesn't have an upper arm the relationships are still the same. The inner pivot has more bearing on bumpsteer then the outer but everything is relative and, if the suspension is designed correctly, the "angle" of the outer tierod is not a good indicator of bumpsteer.
Read this article from Longacre:
http://www.longacreracing.com/articles/art.asp?ARTID=13
The diagram at the end gives you a good idea of what relationships will work. The tierod angle can be just about anything that satisfies the requirements.
Mark
Old 08-30-2006, 03:04 PM
Wiki Edits: 22
very nice link, thank you. theres alot of good info there that i was having trouble finding
im already firmiliar w/ what this image shows
http://www.longacreracing.com/articl.../bsdrawing.jpg
and i know that on a strut vehical, the "upper control arm" is (if i remember correctly) an imaginary line drawn 90* to the strut from the upper strut mount and continueing on to infinity (or till it meets the same line from the LCA)
my concern here is that i might be converting my strut front suspension to SLA (dual a arm) reusing most of my suspension components
i beleive i have the room to do it, and im pretty sure that since my LCA and tie rod are equal length and equal height, ill have "minimal" problem with bump steer, due to the fact that they basicly "share" the same imaginary line
more later ... giotta run ....
Question about the rear end and suspension. rayzorsharp Suspension - Brakes - Steering 4 07-11-2006 07:30 PM
Help...rear suspension design questions FrankR Suspension - Brakes - Steering 1 06-02-2006 07:50 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
4-link suspension design brainsboy Suspension - Brakes - Steering 15 03-12-2004 07:35 AM
Fan Shroud design question Jag Daddy Engine 10 02-23-2004 01:37 PM
