Bunch of newbie questions re SBC
I'm a newbie to the SBC, I'm running a 350 in my Porsche 914. I have the engine and trans out to do some trans work (Porsche trans no like big torque!), and am doing some cleanup work on the engine and engine bay.
I'm shooting for an American car hotrod type engine look, with as few wires showing as possible, highly detailed/clean/simple. Questions: 1. I'm getting the headers Jet Hot coated, but need to get cleaner plugs in the EGR fittings first. I'm going to use something like this. What size plugs are these in my headers? 2. I want to run the spark plug wires under the headers, rather than over, and hide them as much as possible. Is there a kit to do that? 3. The blue capped sensor on the left, and the square bronze water plug on the right on the manifold won't be used anymore. What size plugs do I need to cleanly cap these? And the blacked capped on on the manifold, and the carb: 4. What is the current state of the art for hot rod wiring wrap? Something nice and clean, not the standard corrugated plastic. 5. Who are the good Internet hot rod parts dealers? JEGS and Summit I know about, but they seem to lack on the really "trick" hot rod parts. 6. How do I convert the "AN" size hose and fittings to a number I can understand. In other words, -04AN = roughly what, in inches? Same for -06, -08, etc. Is there somewhere that has the conversions? 7. I am going to be resealing the engine - manifold gasket, pan gasket, front seal, rear main seal, etc. Who makes the best seals? Any tips? Thanks all! |
ya this actually pretty cool a 350 in a porsche somethin custom...nice...anyways, there are a bunch of things to do to trick out a smallblock.....for example with the manifold, if you want to clean it up, you could use a lot of brake clean, to get the grease and excess stuff off....or edelbrock has the brand new performer manifolds with endura-shine, and carbeureters, etc.. also if you want to coat ur headers and get rid of the plug holes, you could just look in your jegs or summit for a nice pair of headers that wont leave your wallet empty..like a pair of shorties or block huggers...one good company for real custom, show quality parts is Big B Auto 866-392-2442, give them a call and get a catalog....they have real good stuff...anyway good luck hope this helps
AN stuff is 1/16 per number = AN 8 is 8/16 or 1/2 inch tube. Blue AN fittings can be polished to shiney silver, the blue comes off with mild wire wheel buffing.
The AN flare fittings are 37* not 45* like other stuff, so no interchanging flares. The pipe size of AN is standard NPT, national pipe thread. Remember AN is aluminum, and screwing it into aluminum you need teflon tape or Felpro Copper anti-seize or it might gall and never come out. You could use brass pipe plugs in allen head or even black steel. Be sure and teflon tape those too. Personally I would use black and paint them the same as the intake manifold Running wires under headers might get hot. The local airport mechanic shop has stuff called "fire sleeve" that you can slip over wires to prevent burning. Most aircraft stuff is orange though. Regular wiring to look hidden can be run inside regular conduit for a smooth look. Paint the conduit for a neat appearance. Aluminum tubing can also be used if you feel inclined to polish it. It comes in fuel line rolls fairly economical and easy to work with. Biggest thing is getting it real straight for appearances. Using aircraft ADEL clamps to secure the tubing is neat. They can be rubber coated steel or nylon. AN or MS aircraft hardware is plated gold color and doesn't rust or tarnish. Instead of rubber hoses you can run aluminum tubes polished or even steel brake lines (painted) or stainless steel brake lines with a small rubber hose connector on each end. If you feel really ambitious, you can run aluminum AN lines to all the hoses and vacuum stuff. Proper stainless steel safety wiring of bolts looks good too, like header bolts. If you are using your existing headers, there should be some local place in a large city near you that coats headers, at least on the outside. Not all can dip to do the insides. If not, I know of one you can ship to. |
| Questions for a sbc rebuild... | Mopar414 | Hotrodding Basics | 3 | 11-29-2005 04:17 PM |
| extreme newbie help | evanps | Hotrodding Basics | 4 | 06-27-2004 07:38 PM |
| 010 SBC casting number question's | stereodud | Engine | 4 | 10-21-2002 06:27 PM |
| sbc questions?? | Harlequin | Engine | 7 | 10-14-2002 12:42 PM |
| Bunch of odds N ends questions | HemmiGremmie | Engine | 1 | 09-14-2002 04:09 PM |
