Bunch of odds N ends questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2002, 04:04 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Question Bunch of odds N ends questions
Hey Crew.
I have a few different questions for ya.
What is the going rate for engines? Its in my Gremlin and Im going to start the new one and a guy is interested, but Im not sure what to ask for it? Heres the quick specs. Newer block, like 87 that has stock heads, 480 lift X 280 duration cam, Edelbrock intake, 750 Holley vacum secondary carb, dual point distributor. Im selling the whol;e thing. From oil pan to carb to alternator and exhaust manifolds. He wants it for an old truck, not to hot rod. Any ideas.
Next. Does a carb like mine(750 Holley, vacum secondary) squirt gas out of the front 2 and back to bowls, or just the front? Cause mines only doing it in the front. At least when its not running. Does it need to be running to do this?
Im thinking about using the new lightning heads from powerhouse on my new project, but the valve size is 2.05X1.60. Would this be to big for the street? I know with to big of heads you loose low end. Or so Im thinking you do.
Thats it. Thanks, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 09-14-2002, 05:09 PM
Quepas00's Avatar
Post
No, you don't have a rear accelerator pump.
