A bunch of sensors? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2008, 08:16 PM
Last journal entry: not a big fan of cherry picker...
A bunch of sensors?
As some may know I am putting an 88 Chevy Motor in my 78 Monte... The Motor was tbi and I am running it now with a carb. It has four sensors on the motor and I just want to be sure what each of them are and what I will just plug and not use... My Dash has the gauge package with the temp, oil pressure and voltage... I have taken pictures of all four... Any input would be greatly appreciate. The Motor is out of an 88 GMC R2500 with a th4oo that was TBI. Thanks in advance. Sleeper
ID:	31390   Click image for larger version
ID:	31391   Click image for larger version
ID:	31392   Click image for larger version
Old 07-21-2008, 09:23 PM
sensors
#1 pic...oil pressure
#2 pic...also oil pressure
#3pic...coolant temp.
#4pic...knock sensor?
don't know why 2 oil pressure senders, both are common sbc locations.
John
Old 07-21-2008, 09:27 PM
Thanks... So on the 78 the knock sensor is not gonna be used correct... no provisions for it... The truck had gauges as well, so maybe one for gauge and one for computer? Should I plug the knock sensor or am I better off just leaving it where it is? Oh and should I use one oil pressure over the other or does it not matter? I am just full of question... but wanna get this right the first time.
Old 07-21-2008, 11:58 PM
#1 oil pressure switch was used to trigger the fuel pump relay.
2 oil sending unit used for gauge and they are different depending on how high the gauge is. ie... 60psi or 80psi. Wont work correctly unless you have correct gauge.
3 coolant temp sending unit also depends on how high gauge goes. You wont need it if you use mechanical temp gauge.
4 knock sensor. you wont need it
I personally would pull them all and plug the holes for the knock sensor and the oil sending unit just above oil filter, and use mechanical gauges. Put the oil line in the hole for the oil pressure switch and temp sensor in the head where the original sensor was for temp.
Old 07-22-2008, 04:07 AM
mmmmm i hooked up my oil gauge to the spot in picture 2 and the gauge isnt working any ideas? sorry to but in on your post i should be able to ge a reading from from that spot i thought, shouldnt have to bleed it should i?
Chevy 454 Sensors flyfishingpage Engine 1 02-03-2012 06:58 PM
454 oil sensors edelbrock3 Engine 3 10-15-2007 02:53 AM
FlatHead Ford Temp sensors. jkrayka1 Electrical 2 08-19-2007 05:49 PM
3 wire oxigen sensors 70bird Electrical 3 04-24-2005 09:32 AM
Hey Crew. Bunch of rambling. HemmiGremmie Engine 1 06-21-2004 08:01 PM
