bunny hoppin - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2006, 12:32 PM
bunny hoppin
i was wonderin how to stop my truck from hoppin all over the place when i get on it i know its going to end up breakin stuff
Old 04-21-2006, 02:11 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
My Chevelle done that till I put traction bars on it. Try that. Should stop it. Hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 04-21-2006, 03:57 PM
97Z28's Avatar
NTI Grad.
Yeah... thats about the only way to stop it from jumping. they're fairly in expensive and are pretty easy to install.
Old 04-21-2006, 06:52 PM
GoneNova/406's Avatar
i had a 70 javelin way back when that did the same thing and cheap traction bars did the trick.if both shocks are on one side of the rear end it would probably stop if you stagger the shocks like they did with camaros or maybe even just change the angle of the shocks but bars would most likely be easier.
Old 04-21-2006, 11:49 PM
who would have traction bars for my pickup the springs are on top of the rearend
Old 04-22-2006, 12:18 AM
97Z28's Avatar
NTI Grad.
www.summitracing.com
www.jegs.com
Old 04-22-2006, 12:59 AM
what kind of truck,springs and shocks do you have?are both shocks on the front or on the rear side of rear end or are they staggered and how much of an angle are the shocks at now?
Old 04-29-2006, 01:11 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Its probably the worn out rubber spring eye bushings.
Install urethane bushings, clamp the front spring leaves, and decent stiff shocks.
Happy easter bunny montea Hotrodders' Lounge 4 04-17-2004 05:28 AM
happy bunny day troy-curt Hotrodders' Lounge 10 04-11-2004 05:44 PM
Bunny Run Jackson Tenn. Dave E Shank Hotrodders' Lounge 0 04-04-2002 11:21 AM
