Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Burn In Triangulated Four Link?
Old 11-30-2012, 09:33 AM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
When setting one up.. Take out all springs or coilover's And set the whole frame at ride height.. If you set everything up at ride height you shouldn't have to put the body on to do it... Frames are built this way everyday... Once you have the frame set up at right height, The added extra weight should be set back to where you started from..At ride height..
