Burned wires in gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2007, 01:11 PM
I had a thread similar to this in the electrical section a while back and now by coincidence I have a very similar problem but this time it is not about what could happen but what has happened. What I have is a 2000 Kia Sportage that the gas gauge failed on and the low fuel level light came on and stayed on. When I removed the fuel pump/sender unit I found the wire inside the tank to the sender had melted, it had not burned in two but it had burned off the insulation completely. After the earlier thread I was left with the impression that the current is limited to the sender and would not be high enough to cause a problem like this but this was, as far as I can tell from what is left, a 16 GA wire and it got pretty danged hot! Is this a common occurrence? My concern here is that there is something wrong besides the sender and that if I just replace it then the same thing will happen again and next time they may not be so lucky and start a fire. Best I can tell, and I may be wrong, it looks as if the wire to the sender feeds into the computer instead of going directly to the gauge so I am a bit leery of checking for power and/or resistance until I find out a little more. ANY info on this, directly related the KIA or not, would be greatly appreciated.
Thanks
Old 10-23-2007, 03:55 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
that is one of those china cars right? do'nt eat the paint.
Old 10-23-2007, 05:06 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Ha Ha Ha Actually I think its a Korean car.
Old 10-23-2007, 05:26 PM
Wiki Edits: 31
Yea, Kia is a Korean car. they had electrical problems around that time period, I know someone with a '00 Rio, it had an electrical fire and got totaled. don't know much else
Old 10-23-2007, 07:09 PM
This is not my car it belongs to a friends daughter, I would not take this POS if they gave it to me! It is a 2000 model with 38000 mi and it is literally falling apart, the screws that hold the fuel pump/sender unit had rusted so badly along with the top of the tank that they just ripped out and left a real mess. I think I can turn the unit a few degrees and drill new holes and the gasket will seal the old ones but he just called to tell me that the unit is nearly $700.00 from the dealer! Not sure if he is going to even replace the sender now.
Old 10-23-2007, 08:22 PM
Wiki Edits: 31
My brother has an '01 Sephia, it's decent. pops passanger side window motor fuses quite often tho. has over 150k on it. the Sportages are crap tho. the Auto's had a problem w/ shifting into reverse in cold weather, often they wouldn't/ won't... Vehicle might value in the $5k range now, consider that w/ the
repair cost's.
Old 10-24-2007, 08:14 AM
pepi's Avatar
oops!.... they all look the same to me, weird logos on upside down bathtubs with wheels and windows.
Old 10-25-2007, 05:31 AM
It's a problem that's not limited to Asian cars... mid 90's GM B-bodies (Caprice, Impala SS, Roadmaster) have the same issues with the in-tank fuel pump wiring.
Old 10-25-2007, 09:49 AM
It must be really common with the KIA because he called around to the salvage yards looking for one and was told they sell them as fast as they come in.
Old 10-25-2007, 10:22 AM
Sounds like a ground problem. That wire in the pump is probably the weakest link in the harness causing it to burn. I would clean all of the grounds. If that doesn't work drive it off a cliff.
Old 10-26-2007, 07:39 PM
68RATVT's Avatar
Last journal entry: 46 Dodge frame
The Ford Windstar had a big problem with meltdowns, even caused a couple of fires, funny they never did a recall though.The problem was corrosion/dirt/grime builds up on the connection on top of the tank, thus making the energy work harder,melt. Ford "Fixed" it by putting a boot on top.
Old 10-27-2007, 08:56 AM
Thanks, I am still waiting on him to decide what to do about this thing and still open to suggestions about what to do. I have done some google research on this and it is surprising that this is a problem but I am finding there are cases of fires occurring from this.
POR-15 gas tank resto kit cruzinTLT Body - Exterior 1 06-06-2006 05:08 PM
Gas Tank 1970 Chevy Camero kan Engine 0 05-21-2006 11:57 AM
32 'Tanks' gas tank - fuel surge/starvation? Limey Simon Engine 2 07-30-2004 01:18 PM
gas tank pressuring up montea General Rodding Tech 3 06-04-2004 08:37 PM
original 1936 ford gas tank fitting bomo General Rodding Tech 5 12-04-2003 04:20 PM
