Burning Coolant? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-01-2012, 01:51 PM
Last journal entry: Current Issues
As for coolant, I just use 50/50
  #17 (permalink)
Old 06-02-2012, 11:03 AM
Well, let me just say I had the same problem. Rebuilt motor and coolant would disappear. Found out that the cars exhaust was a bit white and it was burning coolant..So then I took of the heads and found out that there was a tiny crack in the head gasket. You might have a small crack as well and try to inspect your exhaust very well and if you see some white smoke, you got it.
  #18 (permalink)
Old 06-02-2012, 06:35 PM
B.A.M.F
remove the heads as everyone else stated, send the heads to a reputable machine shop and have them checked then surfaced, also check the decks on the block corner to corner like an
[ X ]then across the center [---] use feeler gauges with a mechanics straight edge which is a precision tool and perfectly flat and straight, verify flat deck surface, when ready to reassemble install a head stud kit from ARP and make sure you put the assembly lube on the threads before installing in the block in order to achieve proper torque
  #19 (permalink)
Old 06-15-2012, 10:39 AM
To give people some closure,
I've concluded that (hopefully) the passenger side's rings just haven't seated yet. The coolant that I was losing is no longer an issue after I:
a) Bypassed the heater core
b) Found 2 small leaks from a not perfectly tightened hose
c) Found a pinhole leak on the radiator
So, I'll give it a few hundred miles, and then we'll see where I'm at.
Thank you guys for your help, it was invaluable!!
  #20 (permalink)
Old 06-15-2012, 12:19 PM
Greg T's Avatar
www.krusinklassics.net
Don't gorget about the intake gaskets. An intake leak can suck a lot of coolant into the engine.
  #21 (permalink)
Old 06-15-2012, 01:37 PM
I'll keep an eye out for that!
I'll make sure I don't lose any more coolant. If I do, that'll be one of my first stops, seeing as it's relatively easy to do. I suppose it's good practice to check fluids before every start-up anyways
'73 Olds 350 Oil in coolant no coolant in oil :( DQ81 Engine 4 09-28-2011 08:46 PM
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 05:37 PM
burning out wrestlingclub142 Transmission - Rearend 56 07-14-2005 10:20 PM
Module burning out scholman Engine 17 01-29-2004 06:19 PM
Burning Oil... HELP iiiezekieliii Engine 3 06-25-2003 10:31 PM
