Burning Oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2009, 09:05 AM
Burning Oil
Everything was fine until I changed my oil yesterday. Used penzoil 10W-30 and now I'm blowing great blue clouds of oil out the exhaust. What happened?
Old 06-16-2009, 09:13 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If there was no smoke, pre-oil change- you have just overfilled it most likely.
If this is the case, drain some oil right away. The oil will become entrained w/air and become frothy. This can kill the bearings, and generally cause trouble.
Old 06-16-2009, 10:07 AM
according to the dummystick it's not overfull, but I will remove some and see what happens.
Would it be possible that it's burning off some gunk?
Old 06-16-2009, 10:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Before you do that, if you are sure you drained all the oil, and the car was level, you should know by how many quarts you added if it has too much. Have to include the filter, also.
I'd hate to have you remove too much oil and have problems due to that, so investigate a little more before you take oil away.
Worst case- drain the oil into a clean container and add again by the quart.
Depending on what engine you have (which is what???), it can vary as to how much to use.
Is this a new car/engine- to you?
Ordinarily, no "gunk" will burn off, due to an oil change.
Old 06-16-2009, 11:03 AM
How many miles on the engine? This was Dyno oil right?
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 08:51 PM
Oil Change THX_138 Hotrodders' Lounge 25 12-20-2006 03:01 PM
Burning oil too much novadan Engine 5 09-09-2004 08:37 PM
63 Jeep F-head Burning Oil..help!!!! slyshar2 Engine 4 12-28-2003 12:46 AM
'54 Flathead Burning Oil Vicioso Engine 2 12-10-2002 11:56 AM
