You should have a resistor mounted on the firewall or near the coil. It is a ceramic type a couple inches long. These are used to lower the voltage to the coil after startup to about 8 volts which allows the coil to last longer. If for some reason your coil has been jumpered around the resistor, that could be why.
That's probably the capacitor for reducing radio interference, shouldn't affect the coil, you can disconnect it to see- possibly a prob. if it was internally shorted to ground, maybe- but doubtful.
Coils aren't known for failing, if there's been any electrical work done under the hood, I'd suggest you go back over everything.
Check the engine ground, if it is not clean and tight it can cause more current to be drawn through the coil to compensate for the bad connection.
Also what is the feed voltage at the HEI batt terminal. If it is over 15V you can burn coils.
Are you using quality replacements like an AC Delco or the Autozone house brand.
Was the distributor cap replaced? Make sure the ground wire inside the cap
is good.Sometimes the ground is a stamped peice of metal and can be over looked in the old cap. This will cause burnt out coils.
The spring that makes the contact between the coil and the carbon electrode to the rotor and the electrode itself can be burned out and/or damaged. This is located under the distributor cap, where the large rubber washer is located. There should be dielectric grease on the washer side that faces the cap.
The metal strap is used in some HEI's under the coil, others have a wire. This must be in place.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
