burning up ignition modules, how many volts to coil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2011, 05:19 PM
munster217's Avatar
Hi,
I think I have just burned up my second ignition module on my Mallory Unilite distributor. I am also using a Mallory promaster coil (model #29440) but not an in line ballast resistor. Should I be?
The car ran, shut it down and 2 hours later no spark to the plugs again. Coil has 11.7 volts going to it wired off of the ignition switch.
Any help would be appreciated.
Old 05-15-2011, 05:55 PM
BOBCRMAN@aol.com's Avatar
These units are very sensative to voltage spikes from a "loose" alternator. Mallory has a fix for it.
Old 05-15-2011, 05:57 PM
munster217's Avatar
What is the fix? I've been reading some online blogs that say it is mandatory to run the ballast resistor (Mallory #MAL-700) or this will continue?
Thanks,
Old 05-15-2011, 07:46 PM
They sell a "spike guard" that fits in the ign wire to the resistor.
Years ago I got to spend a "my expense paid" weekend in St Ignas, Mi. Because a Delco alternator "spiked" my Unilite. No parts in available Upper Michigan.
Old 05-15-2011, 07:47 PM
You definitely need the ballast resistor with the Mallory coil.
Is the Unilite module connected to the coil ignition wiring?
Are you running solid core spark plug wires?
Old 05-15-2011, 08:00 PM
EOD Guy's Avatar
U running an ext or int regulator? Mine kept burning up modules untill I swapped the ext regulator for a internal Alt/regulator, been running good so far
Old 05-15-2011, 08:47 PM
munster217's Avatar
I will get a ballast resistor. Unilite is wired to the Mallory promaster coil via the 3 wire pigtail. Not sure on the wires? Will they say on them?
Old 05-15-2011, 08:49 PM
munster217's Avatar
Exterior regulator. Thanks for the help.
Old 05-16-2011, 02:17 AM
SSedan64's Avatar
The spike filter will also help with the External voltage regulator.
You can check Mallorys site or go to Summit's site & they have Pdf. intructions for wiring. Just look up a Mallory Coil or Distributor & you'll see the link.
Old 05-16-2011, 04:08 AM
EOD Guy's Avatar
Do'in the alt swap was possibly the best thing I have done for my car. It's super simple....... basicly jumping the existing wires coming off the external regulator and adding a wire from the radiator support splice/stud back across the radiator support to the external reg area.
The best thing is no more dim lights!
Bad Ignition Modules!!! WHY??? Sweet-34 Electrical 25 02-15-2008 10:09 PM
Eating ignition modules rorton Engine 8 01-14-2008 04:56 AM
ford ignition modules burn out (often) Jared Engine 7 11-17-2005 12:41 AM
Burning up HEI modules Kobwo Electrical 4 10-19-2003 11:27 AM
Burning up HEI modules Kobwo Engine 11 10-17-2003 10:04 AM
