Burning up plug wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2008, 11:54 AM
5.0Falcon's Avatar
WHY NOT?
Hey guys I got this Jeep that I dropped a 360 into about a year ago, when i did so i upgraded some of the ignition system, basically a MSD ignition box, as well as an MSD coil to go with... The plugs are properly gapped and the plug wires dont touch or rub on anything however I've manage to burn up a stock type coil to distributer wire then just this last weekend a set of 8mm Accels when i found one plug wire was completely seperated on both ends... So... I purchased a set of 8mm MSD helicore wires, but before I put these on and burn them up to what is causing this to happen?
Old 07-29-2008, 12:31 PM
They recomend spiral wound wires not solid wires. Were the runied ones spiral wound?
Old 07-29-2008, 01:49 PM
5.0Falcon's Avatar
WHY NOT?
not sure if those Accels where wound or not...
Old 07-30-2008, 08:17 PM
It's called voltage baby! Accel wires are pretty shaky to begin with and putting msd type voltage will fry 'em fast. Did it look like ash in the boot? and the center core was burned away?
1991 oldsmobile 3.8 ate plug wires fumplet Engine 4 06-13-2007 12:16 AM
plug wires delsman Engine 9 04-22-2006 05:57 PM
Need help picking plug wires Joe 570 Engine 5 02-01-2006 08:30 PM
spark plug wires oldsF85 Engine 5 03-30-2004 11:00 AM
Plug Wires Under Headers 53chev Engine 4 03-18-2003 07:23 PM
