Burnt Valves? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2007, 06:08 PM
On the learning curve.
Burnt Valves?
Hey everyone. I have a quick question. The old heads that came off my engine, some of the valves were a chalky white. What does this mean? Are those burnt valves? Can they be reused or are they toast?
Thanks Steve
Old 05-31-2007, 06:12 PM
Bumpstick's Avatar
Hammer and a torch
No that normaly means that cylinder was firing good and not much in the way of oil consumption... Unless they are of a orange burnt dis-colored appearance they should be ok provided not to many rebuilds on them...?
Old 05-31-2007, 06:17 PM
Oh really? Sweet. Ok one more question then. The heads they were on were "126" heads, a smog casting. The "new" heads I have are "370" 300hp heads. My new heads have valves but they will take quite a bit of work to get useable again, just wondering if my old valves {126} will work. The new valves are 1.94 and 1.50. Does anyone know if the "126" heads had 1.94's and 1.50's? Their still in the heads so I cant measure very well.
Thanks Steve
Old 05-31-2007, 07:26 PM
Wiki Edits: 31
take a socket that fits on the retainer, get an extension, give it a good wack with a hammer. it will release the keepers and allow removal of the valve then just measure with a caliper. I'v managed to clean up some nasty valves, on a wire wheel.
Old 05-31-2007, 07:28 PM
Yea thats prolly the easiest way to go. I know I can clean these valves up but it would be a lot of hard and unessecary work if I could just put my old ones on.
thanks Steve
NASCAR, Unleaded Fuel and Titanium Valves QuenchPiston Engine 18 12-26-2006 09:18 PM
Adjusting Valves and Fuel Pump Install demitristewart Engine 5 08-09-2006 11:10 AM
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 01:19 AM
Camaro compression test....burnt valves??? Rubberman2003 Engine 4 02-08-2004 06:15 PM
Mixed up valves. meschnebly Engine 4 10-07-2003 08:55 AM
