butchlanham - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2010, 03:21 PM
butchlanham
Hi all, This is my second attempt to get some basics on how to check timing of a 2.2 Celica GT. I recently changed the timing belt but might have been a tooth out. So I had to move the location of the distributor until it started. I drove it for three days and all seemed OK. However, it started to lose power and then wouldn,t start. The plugs were fouled with oil. So I replaced them with new Platinum ones, cleaned the throttle body and it started on the first try. When I put it in gear and took off, it fell on it,s face. "NO BALLS". Would someone offer some suggestions as to what,s going on, Please ? Thank You in advance.. Butch
Old 07-03-2010, 06:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the cams are out of phase, just turning the distributor to compensate for the ignition timing isn't the cure. You need to have the cam phased correctly and the timing set correctly- both. The way it sounds, neither is correct.
Old 07-03-2010, 08:52 PM
butchlanham
Thanks for your quick response to my dilema. I inadvertantly found out why my 91 Celica GT, was losing power while in gear. It came to me like a bolt of lightning. You guessed it, the coil wire was arcing on the cold air intake tube. Man, I feel like an Idiot. I hope my painful experience can help someone with the same problem. Thank,s Again for your response. Later.
