Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Buttons?
Thread: Buttons?
Old 12-18-2010, 10:32 PM
Coodeville Coodeville is offline
Originally Posted by DanTwoLakes
You won't be able to find the exact part that holds your button on. You will have to use a #15 button washer, also called a spring washer for threaded nails. Most upholstery shops would have them, but if you can't find any locally, send me a PM and I'll send you some. You may have to trim them to fit under the loop, but you can cut them with a heavy scissors.
The original ones are hog ringed onto the seat in order to pull the button in. Can you hog ring the #15 washer?
