Buttons? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2010, 12:08 AM
Buttons?
What's the right way to get this off? Just pry it?
Old 10-28-2010, 06:54 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Get something pointed ( like an ice pick) and force it into one of the 4 cracks around the button. Once you pry up one of the 4 quarters, it will be easy to remove the button.
Old 11-18-2010, 05:55 PM
It was a real task to get these buttons off. Some were damaged. Where can I get the part that holds the button on?
Old 11-19-2010, 07:02 AM
Wiki Edits: 22
You won't be able to find the exact part that holds your button on. You will have to use a #15 button washer, also called a spring washer for threaded nails. Most upholstery shops would have them, but if you can't find any locally, send me a PM and I'll send you some. You may have to trim them to fit under the loop, but you can cut them with a heavy scissors.
Old 12-18-2010, 10:32 PM
The original ones are hog ringed onto the seat in order to pull the button in. Can you hog ring the #15 washer?
Old 12-19-2010, 09:35 AM
Wiki Edits: 22
If it was me doing it I would just wrap some button string around the washer and pull it in that way.
Old 12-19-2010, 11:56 AM
That's probably eaiser than hog ringing it back in. I really had to fight with the thing. It's probably easier to do with an assistant.
Question: Through my research I'm coming to the conclusion that you have to fabricate new ones if needed. Am I right? I've seen through some web sites that buttons have there own specicific sizing terminology. In my case, it's a # 45 which is 1 1/8. It looks as if kits are offered to make these buttons. But they are expensive. Is there anywhere I can pick them up arleardy made and ready for installation?
Old 12-26-2010, 04:56 AM
Wiki Edits: 22
No, not ready made. You need to find someone with the machine and dies to make the buttons from scratch. I have a button making machine, but the largest size die I have is #40 and the cutter and top and bottom dies for size #45 would cost over $100. I have a supplier that will make any size button for me. I would need you to send me enough leather scraps to make the buttons with. Also, send one of the old buttons along to make sure you get the right size. Send me a PM.
Old 01-18-2011, 04:55 PM
Ok, so now I have my buttons. Can I find the string on perfectfit.com? I want to check it out. I might go that way instead of hog rings
Old 01-18-2011, 09:46 PM
Wiki Edits: 22
They don't seem to have it, but these guys do: BUTTON TWINE
Old 01-18-2011, 11:43 PM
Midwest Fabric has it as well.
Made my own door release buttons. americanLT1 Body - Exterior 9 08-21-2007 08:34 PM
Seat belt latch retainer buttons - where can I get them? willys36@aol.com Interior 7 01-30-2005 04:41 PM
Steering Wheel Control Buttons 38Chevy3WCoupe Electrical 2 11-13-2004 06:11 AM
Sliders or Poly Buttons???????????? Darkman270 Suspension - Brakes - Steering 4 10-24-2003 05:36 PM
