Buy Wheel Tubs or Build Your Own????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2008, 10:31 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Has anyone used the 24ga. steel wheel tubs from Jegs? I am ready to start tubbing my S10 but 24ga. seems really light. I have the capability of making my own and was thinking maybe 20ga. I know the thinner, the lighter but I need durability too. Suggestions?
Thanks
Old 03-31-2008, 06:11 AM
BOBCRMAN@aol.com's Avatar
If you got the tools/materials. Make em!! Simple job.
Old 03-31-2008, 06:31 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I agree! If you are going to drive on the street though I think I'd use 18 Gauge-
Old 03-31-2008, 09:07 AM
powerrodsmike's Avatar
Wiki Edits: 161
I don't know how big your tires are going to be, but I've used trailer fenders and filled in the cutout on the inside. They are usually 16 gauge and have a rolled over edge that looks much better than the pinch crimp rolled seam that you usually find on the economy tubs.
24 gauge is almost tinfoil. I use 18 G on most everything that requires sheetmetal..
Later, mikey
BE different....ACT normal.
Old 04-03-2008, 01:26 AM
327NUT's Avatar
Ditto on the trailer fenders, we used them on a buddy's Mustang for minnie tubs, .....and they are cheap!
Old 09-16-2013, 01:17 PM
Where do you get trailer fenders?
Old 09-16-2013, 02:53 PM
Wiki Edits: 27
old post ?
look in a large phone book for RV-trailer supply or stop by a Rv dealer and ask where there is a local dealer.
The Following User Says Thank You to timothale For This Useful Post:
V8Square (09-17-2013)
Old 09-16-2013, 07:27 PM
life is a temporary assignment
They are to easy to just build..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
Old 09-16-2013, 07:32 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Holy Thread Resurection... April 2008
If you have a store near you that caters to farmers, like a mercantile store, they'll have trailer fenders. That's where I buy mine at.
I did a google search for "farm supplies ballwin mo" and found this: http://www.orschelnfarmhome.com/edea...trailer+fender
Or you could get them online, but shipping usually is outrageous: http://www.etrailer.com/Trailer-Fend...FUJqMgodxE4AJA
Hope that helps!
The Following User Says Thank You to lakeroadster For This Useful Post:
Old 09-16-2013, 07:48 PM
The reason they are so light is,they have a seam that interlocks,then you have to fold the edge over,18g would be tough to do that to.On street cars,I just make my own from 18g.
The Following User Says Thank You to Actionjk For This Useful Post:
Old 09-17-2013, 04:30 AM
astroracer's Avatar
Back from the dead thread but I'll throw some info into it...
I used the stock tubs from the van when I tubbed it. Raised them 4 inches and widened them 8. I used 18ga sheet to make the additions.
The Following User Says Thank You to astroracer For This Useful Post:
Old 09-25-2013, 11:19 PM
Hello Every One
I am working on a bagged 68 Chevy short/wide pick up. The front section of the bed floor was raised 4" and the cross braces underneath were C notched for driveshaft clearence. This left a 4" difference in height between the front of the bed, ahead of the "bridge" or GIANT C notch cover, and the back of the bed behind it. I trimmed out the mounting bolt holes and was left with an opening 39 1/2" wide. Round tubs would have been taller than the top of the bed sides, so with the help of some Miller High Life, I got an idea. I didn't want a "square"edge on the tub,so I ordered two, 2.5" U mandrel bends and some 2.5" exhaust pipe then got to hacking. I figured the height and width that I needed to clear 30" diameter tires when the truck is on the ground, set the angles so the bottom was 39 1/2" wide and welded them together. The first picture shows the exhaust tubing welded to a sort of U, the next is the same piece after I cut out just over 1/4 of it to make my 90 degree corner. The rest of the pictures show the 16 gauge cold rolled being added. You could use any size pipe or tubing that you want to get your desired radius. I hope this helps someone.
Anthony Cole
Hammers Construction Inc
ID:	83898   Click image for larger version
ID:	83906   Click image for larger version
ID:	83914   Click image for larger version
ID:	83922   Click image for larger version
Old 09-26-2013, 03:33 AM
astroracer's Avatar
Nice! looks great!
I did the same thing for the front wheel wells in the van! Was a lot easier then trying to form something with my limited sheet metal skills.
We worked on the left wheel well and got it fleshed out real nice. We ended up re-making the piece I had fabbed a month or so ago. Needed it about an inch wider and didn't want to scab in a piece.
We quartered up a piece of 3" dia. muffler tubing to make the rolled edge.
While I was playing with the welder Mel remade the pattern for the new wheel well. Here is the new piece all fit in and ready to weld to the tubing.
Here is a pic from underneath. This provides PLENTY of room for the tire at full jounce/full steer.
Here it is after tacking.
We pulled it out and finish welded it. After a bit of sanding we clecoed it back in and started making the inner skirt.
This is how it looks underneath right now.
The pattern (in white) for the inner skirt.
Mel finishing up the inner skirt in steel.
The skirt clamped in place. We have a little trimming to do yet and are planning to run a bead around the bottom edge to add some strength.
A look under the skirt...
Here is a couple of pics after the first coat of primer.
Mark
Should I buy an English Wheel and a Planishing Hammer? CrashFarmer2 Garage - Tools 42 02-25-2008 09:41 PM
Want to buy RAT ROD or build same gsipesnc Introduce Yourself 3 01-14-2008 01:48 AM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 07:52 AM
Dyeing factory steering wheel? Hippie Interior 3 06-02-2005 03:33 PM
