Buying GM Vortec Crate Engine need some advise - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2012, 05:07 PM
GUITAR1989's Avatar
Guitars & Cars >8D
Hey guys I finally have the $$$ to order an engine I was just wondering about a few of the parts ill be needing for the install. Im getting Chevrolet Performance 12530283 Chevrolet Performance 1996-2000 Truck 350ci L31-R Long Block Assembly
Its a 4 bolt roller vortec crate from jegs 1830$ and free shipping this month
Im going to be putting it into my 1974 stepside. when i go to oreilies and type in flexplate for 1996 silverado it brings up flexplates for the engine just they all say only warrentied with 4l80e but will they work with my TH375? also internal/external balance, 168/153 tooth, 10.75"/11.5"??? all the options are throwing me off. what one should i get and will it work with my current pre 86 starter or will i have to get a specific one for this new vortec engine?
another thing im wondering is what intake to get should i get an idle-5500 intake or 1500-6500 pretty much should i get a preformer or rpm, street warrior or stealth? Just not sure if the higher rpm intakes would be good on my barely modified crate vortec engine.
Im leaving the lame cam stock so i dont void the warranty just yet. ill freshen it up and do a cam swap and head work later on down the road after i get my fill of the waranty
Thanks for taking the time to read
Old 07-20-2012, 05:52 PM
For a flex plate you need GM part 14088761. This is for Vortec/Swirl Port Gen I engines with the one piece rear seal. The change in the crank flange requires a small amount of balance weight be added outside on the flywheel or flexplate. Technically this makes the engine externally balanced but this is nowhere close to that required by some 383 strokers or all 400's. The Vortec also doesn't use an externally balanced damper on the front like the 383 stroker and 400. But you get the correct damper with the long block you ordered so aside from its good data to know this isn't a problem for you. This is a 168 tooth wheel. Your current starter will work but the new mini starters are miles ahead in cranking power and reliability. This flex plate is drilled for both bolt circle diameters or 10.75 or 11.5 inches. This flexplate will work for a 700R4, 4L60, 4L60E, or 4L80E and the variations of each and will all work with the TH350/375 or the TH400 converter.
The Vortec has a roller cam it is quite a bit better timing wise than the flat tappets before it. Especially if you're thinking of adding more cam down the road, I'd go with the Edlebrock Performer RPM. Yes it surrenders a small amount of torque on the bottom end, but it is way better from 1500 RPMs up than the regular Performer.
Bogie
Old 07-20-2012, 06:06 PM
GUITAR1989's Avatar
Guitars & Cars >8D
Nice thanks for the info man thats just what i was looking for, I actually just placed the order for my fuel pump, weiand intake and vortec 4 bolt roller crate engine!!!! Ive been wanting to get this for a lonnnnnng time now,,
Old 07-21-2012, 12:10 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
let me know how things turn out cause i have a 86 chevy truck and i eventually wanna go crate vortec
Old 07-21-2012, 05:49 AM
I can't help you on your flexplate issue, I just want to comment on that engine........
That is by far the best "crate" deal out there right now. I saw it in Jegs, and it's a little hidden gem amongst the other engines. 4-bolt main, 1-piece rear main seal, roller cam, 9.4-1 compression, vortec heads. The only thing I don't like is it has no mechanical fuel pump provision but that is not a big deal. That motor was around 260hp from the factory if my memory is correct. If you have the ambition, pop in a slightly hotter camshaft while the engine is out. Those heads will respond very well.
COMP Cams 08-412-8 - COMP Cams Xtreme Energy Camshafts - Overview - SummitRacing.com
COMP Cams 08-502-8 - COMP Cams Xtreme Energy Camshafts - Overview - SummitRacing.com
Old 07-21-2012, 07:20 AM
GUITAR1989's Avatar
Guitars & Cars >8D
Yeah I want a different cam but putting one in would void the GM Warranty so Im going to wait to do any modifications to the engine.
I actually have another question for you guys Ive seen some pretty horrific pics of the plastic vortec intake manifold gaskets melting and I was wondering what intake manifold gasket you guys suggest using to seal the vortecs to the Weiand manifold. Ive seen suggestions of FEL-PRO MS98000T and FEL-PRO 1255 gaskets. Anybody know the best gasket to use?
also do any of you guys know if it voids the warranty if I install the engine myself and not a professional?
Thanks for the responses
Old 07-21-2012, 06:44 PM
Banned User
i'm very interested in this engine myself.
Is there a definitive way to find out if the cam on these engines has the fuel pump lobe drive or not?
Old 07-21-2012, 07:42 PM
GUITAR1989's Avatar
Guitars & Cars >8D
That's the fuel pump I ordered with my engine. I was wondering.. Since the pressure put out by this pump is fine for my carb and there's no need for a regulator do I not need a fuel return line so it doesn't heat up?
I'm honestly really thinking about a cam swap. Since I don't want to fork over my hard earned cash for a "professional" install and don't wanna pay to have my truck towed to a place and pay for inspection...I kinda wanna just say screw the warranty and get a good cam and spring set. I'm not gonna get to into that till I can get an answer from a gm rep about if me doing the install voids the warranty.
Old 07-22-2012, 07:02 AM
Whatever cam you use, don't get confused by hot rod articles for the older SBC and get carried away with initial timing advance. On the older SBC 350 with poor flowing heads many folks tried very advanced initial timing. Factory setting was only 4-8 degrees, but using a base timing of 12 or more (up to about 18) was very common. However, the Vortec heads don't have the same flow characteristics and high base timing is not a good idea.
Bruce
Old 07-22-2012, 12:17 PM
Just my 2 cents,
If your using a stock rear gear in that truck(just fine), I would stick with the cam that comes with the crate engine, stock convertor, add performer vortec(or similar) dual plane intake, 600cfm Holley vacum secondary carb, and 1-5/8" headers with 2-1/2" dual exhaust. Limit max timing to 34 degrees.
You don't need the higher horsepower that comes with a larger cam(or reduced milage) in a truck. They don't handle all that well at high speed.
I beleive that you would be happy with the zero to sixty mph acceleration, off idle torque, and great throttle response. If you just want the sound of a bigger cam, thats another story.
Give it a try while you already have it.
Like I said, just my 2 cents.
Good luck,
ssmonty
Old 07-22-2012, 02:29 PM
The cam in it is so mild you could easily find power and sacrifice NOTHING. Keep it under 215 degrees and you won't even hear it. I'd go a touch hotter like what I suggested earlier. For $1800 I wouldn't worry about the warranty. They build these motors VERY robust. 4-bolt mains aren't even needed until you get well over 400hp, and guys go higher with 2-bolt mains and have no issues. They put this motor in millions of trucks so they know the recipe very well.
Old 07-22-2012, 03:31 PM
studeelover's Avatar
Why not one of these....
It already has a cam, dyno tested with dyno sheets.
Blueprint Engines SB-Chevy Budget Stomper w/Aluminum Heads 355ci/ 375HP/ 400TQ - JEGS
Old 07-22-2012, 04:29 PM
Oops , I meant
This one. The price is better.
Blueprint Engines BP35511CTC1 Blueprint Engines SB-Chevy Budget Stomper w/Cast Iron Heads 355ci/ 310HP/ 360TQ
Old 07-22-2012, 06:56 PM
BigEd36's Avatar
Im going to be putting it into my 1974 stepside...............................
Im leaving the lame cam stock so i dont void the warranty just yet. ill freshen it up and do a cam swap and head work later on down the road after i get my fill of the waranty ...........................................
Yeah I want a different cam but putting one in would void the GM Warranty so Im going to wait to do any modifications to the engine.......................
I'm honestly really thinking about a cam swap.........I kinda wanna just say screw the warranty and get a good cam and spring set. I'm not gonna get to into that till I can get an answer from a gm rep about if me doing the install voids the warranty..................
Guitar1989, you can read the GM warranty (in PDF) here: http://www.crateenginedepot.com/pdfs...ne_Warrant.pdf. After reading the warranty, looks like you won't be waitin' long for the warranty to expire. If I'm reading it correctly your Vortec long block doesn't fall under the Performance Parts, it's a GM service parts replacement. Putting a Vortec into your '74 pickup will fall under the "Parts-only warranty for non-cataloged applications", and it's only 12 months or 12,000 miles. For a camshaft for your Vortec you might want to consider the GMPP #14097395. It's the cam used in the 383HT (high torque) engine and the 350 Ram Jet, it's popular for more power in a Vortec 350. With .431/.451 lift it will work with all your stock Vortec valve train. It has a fuel pump lobe, although I don't believe your Vortec block will be drilled for a mechanical pump. I would probably put the engine in stock, run the crap out of it for a while to see if any problems show up while under the warranty, then change the cam. Then again, with the Vortec's reputation for reliability, I might just say to hell with it and change it before putting it in, it's a lot easier that way, and you don't have to pay for a second set of gaskets.
Old 07-22-2012, 08:28 PM
Like BigEd said, if you change it now you can re-use the gaskets. Plus it's WAY easier to change a cam on an engine stand then in the car.
V6 Vortec crate engine problem Walldiver7 Engine 1 06-11-2012 02:21 PM
need advise on buying a blower gaurdian101 Engine 3 03-07-2012 09:56 AM
Computer chip for 96 5.7 Vortec performance crate engine chucksrt Engine 12 12-01-2010 11:39 AM
Need some advise on buying a used truck.. 383MontecarloSS Hotrodders' Lounge 14 02-25-2004 03:52 PM
