Originally Posted by 68NovaSS
Carb favorites, likes and dislikes are always an area of contention here, as 301nova says, you can get a bad apple in the bunch. I've got two BG Mighty Demon 750 BC's on my 8-71 blower motor and couldn't be happier. Many other carbs would be just as good when sized and tuned properly. That's the key to any performance tune, that's a given. I've never owned a Predator, when they came out they were controversial, I think they've proved themselves through the years, they're a whole different animal from the norm.
I can't get to emotional over a carb, not enough to throw out the 'POS' card, but would certainly pass on information about the bad and good experiences.
RPM doesn't explain his dissatisfaction, I'm curious what the problems are.
Bought the Demon and installed it on a new 383 stroker, ran just fine for about 2 months. Coming back from a show late at night the cars starts to miss fire pretty bad and was only about 3 miles from home so I just drove it on. Any way the carb is now running so rich that raw fuel is running out the right side header. Figure I got a stuck float, so I look down the carb and no fuel dripping. So I called BG talked to a tech and was told to check all kinds of stuff. It all checked out OK. So I called them back ( over a period of a few days) got a different tech, same old stuff check, check check. Finally took the carb all the way down and found the problem. Seems BG left a plug out of the base of this carb, and over a period of 2 months it finally sucked a hole in the metering plate base gasket. This big hole was dumping all the fuel under the butterflies and could not be seen. So I called BG back 3rd time and explained what I found. Tech says oh yea we have had quite a few of them, someone on the line was forgetting to install the plug. Said if I paid the freight both ways the would be happy to install a plug. I said what about this new motor that has cylinders washed down and need to come back apart and be fixed. Nope the warranty does not cover that. So I just fixed it all myself and put it back together, runs fine now. The pictures are in my gallery if you want to look at them. So now you know why I say BG is a POS.
If you look at some of the other threads on my problem with BG you will notice that the BG rep will not talk about this carb or even address it!
