Buying a new set of points - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2011, 12:29 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
In all honesty, I'm AFRAID of what the 'McParts stores' might try and sell me nowadays... It's been way too long since I have even bought a set of points.
I need them for my ol' dump truck- a '75 GMC 6500 with a tall deck 427. I have the ol dwell meter handy... so..
Where might one find a quality USA made set of points that can be trusted?
Old 06-17-2011, 12:48 AM
blue54's Avatar
Should be able to get Echlin at NAPA or Accel brand where they sell hot rod parts. Their still made in USA.
Old 06-17-2011, 03:46 AM
sqzbox's Avatar
My pipes are my music
X2 on that^^^. Napa should have it or can get it. Don't forget the condenser also.
Old 06-17-2011, 04:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Uniset, but at least the price is better than most- http://cgi.ebay.com/ebaymotors/STAND...item23118443b8
Old 06-17-2011, 07:07 AM
Wiki Edits: 31
Rockauto still sells Blue Streaks. It's all I'v ever used
Old 06-17-2011, 07:49 AM
cranky1's Avatar
Just stuck
Same here....
Old 06-17-2011, 08:35 AM
ogre's Avatar
the 'Duracell Project'
who uses points anymore?
buy a pertronics for that truck and never buy points again
Old 06-17-2011, 12:13 PM
Say bye-bye to the dwell
If your distributor is in good shape, with no wobble in the breaker plate and no excessive thrust in the distributor shaft, a Pertonix kit is the only way to fly. You will not have to stand on your head setting the dwell every few weeks.
The best available points are NAPA Gold (Echlin) because have a 38 oz spring to prevent point bounce at high RPM. They are just like the old ACDelco D112P points that worked so well in the high performance SB & BB Chevy engines with point type ignition systems until they were finally discontinued in 1985, but they required frequent dwell adjustments. The good ACDelco D112P points were replaced by ACDelco D106P which are nothing but junk, have an 18 oz. spring and are made by Mexicans.
Old 06-17-2011, 01:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by MouseFink
...and are made by Mexicans.
You 'say' that like there is something inherently wrong w/a Mexican. I will submit that the problem is in the materials the part is manufactured from- not the nationality of the labor force assembleing them. I will refrain from accusing you of being a racist pos.
Old 06-19-2011, 02:19 PM
cranky1's Avatar
Just stuck
There are several that run points on unrestored cars or want to stay 'completely' original and doing a tuneup isn't hard. If you're not running high rpm, don't use the points with the high spring rate then you won't have to dwell it so often. The high spring rate 'anti bounce' points wears the rubbing block faster. My tuneups lasted well over a year on my daily driver 66 Belvedere. Part of that was 'over' tuning or setting the points a little wide and gaping the plugs a little tight and letting the tune drive in and used good parts. I don't mind doing a tuneup actually....plus I don't have to carry spare pickups, ECM's and the like.
Old 06-19-2011, 02:50 PM
C-10's Avatar
Revolution Calling
Yeah the reason for even messing with points is because this truck has the governor setup. It's got that funky Holley carb that is plumbed to the point type distributor. They work in conjunction to govern engine revs. Common on the medium duty GM's.
Usually an HEI swap would do the trick, but I'd like to keep the governor intact.
The pertronics deal is a neat piece.
Curious, is the Blue Streak points known by any other brand? Can't find them on Rock Auto..
Old 06-19-2011, 02:56 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Pertronixs i have used them a few times and they are a pretty good investment IMHO and you can still keep a set of points around just in case and swap right back no problem.JMO
Cole
Old 06-19-2011, 03:03 PM
cranky1's Avatar
Just stuck
IIRC, Standard Motor Products make them....
Old 06-20-2011, 01:00 AM
Wiki Edits: 31
Yep. Standard motor products, Blue Streak line
Old 06-20-2011, 03:30 AM
willowbilly3's Avatar
Last journal entry: Body mods
Points distributors will tend to wear the bushings faster than an electronic unit due to side loading from the spring, which is accelerated with the high performance points like the Echlin Gold ( which is all I used back in the day).
I have noticed the quality of points seems to have deteriorated in the last couple decades. All of them I have installed in the last few years practically go closed in the first 500-1000 miles due to the crappy material in the rubbing block. After the get run in and reset they seem to last ok. The last vehicle I had with them got a petronix, best move I made.
buying 350? Cape Cod Bob Engine 9 09-15-2007 06:49 PM
Buying this car.... Gabriel Hotrodding Basics 24 09-02-2006 11:36 AM
New car buying need help Maverick Hotrodders' Lounge 5 09-23-2004 12:01 PM
I'm looking at buying this little 4x4 neil madsen General Rodding Tech 27 05-18-2003 06:43 PM
Buying used pistons a good idea? also buying a used cam? LoudMalibu Engine 5 03-20-2003 01:53 PM
