buying a new truck and need info - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2011, 02:24 PM
the seller is stating a lot of info about the engine and truck built
1. I would like to see with some pros if it makes all sence, and if it is possible (700HP)
2. I would also like to know if anything seems missing or what questions i should ask
here it is:
1964 Chevrolet C10. This has the best of everything and was professionally built. Blown 8.5:1, 355cu.in. 4-bolt main "010" High Nickel Heavy Duty Chevy small block, ARP Studded, fully balanced and blueprinted, Steel Forged crank, TRW Blower Pistons, and the latest cast 202 Bowties heads fully ported polished and cc'd with Manley Stainless Steel Valves. The only oil used is Royal Purple Synthetic 20w50 with a Mobil 1 big block Synthetic Filter. The Blower is a Polished Weiand 6-71 being underdriven by 9%. Twin Edelbrock Performer Series 600cfm Carbs custom done for Blower Applications topped off with a Polished Aluminum Hilborn Style Dual Quad Blower Scoop. MSD Pro Distributor, Blaster Coil, and Taylor Wires. Griffin Aluminum Radiator with a 16" 2100Cfm Perma Cool electric Fan. Billet Specialties Pullies, Valve Covers, Breathers, Wire Looms, Line Clamps etc. Lokar Braided Throttle Cable, Gas & Brake Pedals and Engine & Trans Dipsticks. All true Stainless AN Braided Lines And Stainless Hard Lines even the Brake Lines. Custom Headers and Flowmaster Mufflers HPC coated and chrome plated full 3" exhaust system all the way to the tail. Putting out about 700HP w/out any Nitrous here! Runs fine on premium pump gas. It has a smoothed and moulded in Volare / Aspen Subframe, all the front suspension components are new and have been replaced and are either chrome plated or painted to match the body. The trans is a full manual pro built TH400 with a forward pattern, B&M 168 Tooth SFI Flexplate, 3000 stall converter and a B&M ratchet shifter. The rear is narrowed and totally rebuilt with a 3.73 posi unit. The Custom rear suspension has Aluminum & Chrome Pro Coilovers, a Polished Stainless Steel Panhard Bar and a Custom Made Chrome Plated Driveshaft. Autometer Pro Comp Liquid Filled gauges and a hidden Wiring Harness. The polished stainless Fuel cell is hidden under the bed floor and between the frame rails, it is connected to a Mallory Fuel Filter & ProComp 140Gph/14Psi electric fuel pump. The Fuel Line is 1/2" (#8AN) braided and stainless hardline all the way to the front.
Old 01-06-2011, 07:09 PM
Check your spark plug gaps
Is there a question to this post?
Old 01-06-2011, 07:39 PM
327NUT's Avatar
The truck COULD have everything he states it does.......but as we all know sometimes the equipment list gets embellished a little. Ask the seller for receipts for the parts and all work done. Also ask who did the machine work, if the seller balks at ANY of this.....see ya!!
Had a guy in '78/79 that bought a blown 355 sbc, supposedly had all the good forged stuff and built by Joe Mondello's shop including a set of Joe's ported heads. Turned out it was a stock Target Master engine with a 6-71 on it.....buyer beware!!
Old 01-07-2011, 05:19 AM
yeah the is 2 questions
first and most important is
is 700 HP possible with a 350 010 block bored to 355 with all these components?
Old 01-07-2011, 06:39 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
It is possible, 90% of what you posted has nothing to do with how much HP the engine is capable of.
Old 01-07-2011, 07:00 AM
well now you see my ignorance
what questions should i ask
and what is the 90% that i should ask
tks
Old 01-07-2011, 07:45 AM
delawarebill's Avatar
engine hp
a friend bought a big al's toy box motor with 6-71 blower. its was a 355cuin motor and dyno'd at 750hp.. he had dyno sheet.
and it was in a bucket.. i drove it once and never again..
Old 01-07-2011, 07:55 AM
68NovaSS's Avatar
Wiki Edits: 9
Static c.r.? Cam specs? What differential? Who built the trans?
Like 327 says, show me receipts, pictures, spec sheets. Keep in mind there are some things you can't verify, the internals.
Old 01-07-2011, 08:25 AM
How fast is fast enough?
Most of the time you can tell a lot by how the thing looks. If everything is pristine and neat and doesn't look like he cheaped out anywhere then it probably is pristine, and neat, and he didn't cheap out anywhere.
for the engine, you can ask all of the details, and those are nice if he remembers them (I can't always remember every detail of all the stuff i built), but at 700hp he will be able to provide a dyno sheet, chassis or engine dyno. You don't stumble upon a 700hp combination and not have the thing tuned properly.
Old 01-07-2011, 09:06 AM
bentwings's Avatar
bentwings
I'd call bull on this one. Big Al gets about 11g for 600+ hp. You are talking about a race motor on the street. Can you let it sit in gear and idle untouched for 45 min in 95 deg heat with the AC on?? A local guy does E-85 carbs and has about 700 hp in his 383. It runs very well and is as close to a daily driver as you can get. Only problem is where do you find E-85 out in the country back roads??
Next the heads are bowtie?? What you will need something aluminum that breathes very well supercharged for this kind of hp.
Underdriven 9%, give me a break, maybe 6-7 # boost.
Better have him run it on the dyno for you.
327nut has a good point
Buyer beware
Old 01-07-2011, 05:41 PM
maybe we should go from here, what does this 700 hp truck cost?
Old 01-07-2011, 06:16 PM
why does price matter?
buying a new truck and need info locomotion Hotrodders' Lounge 7 01-10-2011 03:42 PM
buying a truck zcxtmi Hotrodders' Lounge 8 09-15-2006 04:21 PM
Buying new heads - need general info vetteguy Engine 11 04-09-2005 03:16 PM
Need some advise on buying a used truck.. 383MontecarloSS Hotrodders' Lounge 14 02-25-2004 03:52 PM
Buying used pistons a good idea? also buying a used cam? LoudMalibu Engine 5 03-20-2003 01:53 PM
