have you got a Tractor Supply Co. close by? they have a sale on Hobarts every now and then.
I am in the same place, but I would go with a 230v if you can. Around here a Hobart 175 is around $609 and a Millermatic 210 is about $1300. But then again if this is for smaller stuff and clean metal the 110v should work.
Small stuff around the shop. Just for my use. I think the 110 will work fine. I have looked at the Hobart and it looks pretty nice. The Miller would be great but I think they are more than I want to spend right now.
I bought a Campbell Hausfeld 80 amp wire/mig welder for $249.00 and it has turned out to be a real work horse. Surprised me as I didn't think it would hold up that well. 4 amp range settings and variable control over the wire feed. I've burned up about 3 dozen rolls of wire welding just about everything and haven't had to replace any parts yet. For lightweight general use it seems to be a pretty good buy. Found it at a Wal-Mart and thought for the price it was worth a try. It will kick off if you really push it hard and it gets too hot. Turns back on when it cools down. Even has the gas regulator and hoses for the argon bottle. Have to find your own bottle though.
I have a 220v Lincoln stick welder that doesn't get much use after I picked up the wire feed. Love that machine! |
I think Lincoln is a pretty good welder. I have a 135 and for around the house and automotive use is just great. Just make sure you get a gas welder. I think I paid a little over $500 at Lowes.
Kevin |
This is the MIG I have http://www.htpweld.com/product_page/...s/mig_140.html I'm extremely pleased with it. The best piece of equipment I ever bought!
I did a lot of research on all MIGs before I bought this one. I thought it was the best bang for the buck. Compare duty cycles to otheres! Mine has been absulety flawless and very well made! As an electrician by trade, I fully understand that the 135 pounds is largely due to a better transformer! HTP uses copper windings and a lot of iron. A lot of others are using aluminum wire in their windings and less irion in their transformer cores. This is the MIG I have http://www.htpweld.com/product_page/...s/mig_140.html I'm extremely pleased with it. The best piece of equipment I ever bought! I did a lot of research on all MIGs before I bought this one. I thought it was the best bang for the buck. Compare duty cycles to otheres! Mine has been absulety flawless and very well made! As an electrician by trade, I fully understand that the 135 pounds is largely due to a better transformer! HTP uses copper windings and a lot of iron. A lot of others are using aluminum wire in their windings and less irion in their transformer cores. This is the MIG I have http://www.htpweld.com/product_page/...s/mig_140.html I'm extremely pleased with it. The best piece of equipment I ever bought! I did a lot of research on all MIGs before I bought this one. I thought it was the best bang for the buck. Compare duty cycles to otheres! Mine has been absulety flawless and very well made! As an electrician by trade, I fully understand that the 135 pounds is largely due to a better transformer! HTP uses copper windings and a lot of iron. A lot of others are using aluminum wire in their windings and less irion in their transformer cores. Last edited by Huskinhano; 03-03-2004 at 06:02 AM. |
hey diablo, I've been thinking about making the same purchase. Have you used the welder yet? If so, what were your thoughts. I'm a newbie at welding and wanted to know if this is a fairly decent unit. Thanks,
Garrett |
......FREE NATE!!! |
I have a Hobart 135 too. I just love it. It works great for everything I do around my garage. I also have an off brand stick, but I haven't used it yet. I still have to get the right 220 plug so I can plug it in.
| Recent Garage - Tools posts with photos |
