Originally Posted by poncho62
About the "T" tops, jack up one wheel of the car and see if there is movement in the gaps around the tops and the doors etc..try it on each corner. That will tell you how solid the frame structure in the unibody is.
Thanks man that was some great info I will be sure to test that out tomorrow when i go back Ill let you know how it went.
