Thanks for the input Ray and thanks for welcoming me. The car is being sold to me by my uncle who is willing to workout a payment plan for $100 a month and he has a around 25 of the 1979 model TA around his property I chose this one because he said it was running before and shouldn't be a hard fix but I'm wondering if the body is pretty solid for a start because he does bodywork and says he will do it for free and will take part from other cars to make this one whole again, or should i go with one that has a better body and start my work around the engine? I honestly don't know which one will take more time and i want to be driving one as soon as i can with a pretty decent looking car
Thanks in advance for any input |
If you have a number to choose from, take the one that has the best body....anything else can be changed easy enough. I would be concerned with the "T" tops....prone to leak and they are more prone to body flex than a solid roof car
Ontario Rodders |
| The Following User Says Thank You to poncho62 For This Useful Post: | ||
1979 TA (11-24-2012) | ||
Great information thanks for your input |
I will send some pictures of all the cars in his yard there A LOT it was like i was in heaven when i was there lol. But it is a shame that those cars sit there like that but he is in the process of restoring some of them so not all hope is lost for them. Hopefully ill be going back tomorrow.
About the "T" tops, jack up one wheel of the car and see if there is movement in the gaps around the tops and the doors etc..try it on each corner. That will tell you how solid the frame structure in the unibody is.
Ontario Rodders |
Just make sure the rear frame rails are ok in the areas around where the leaf springs attach. The frame rails go bad in those spots.
It looks like that T/A is going to cost an arm and a leg to make it nice, it won't be worth a arm and leg when you get done with it. Start out with the best body you can find, everything else can be replaced.
If he was a good uncle he would be cutting you some slack on one of those shovel nose Firebirds or the El Caminos. A towing package and T tops? By 79 they were using highway gears for better fuel economy. There are codes on the rear end to find out what gears are in it. Look for a aluminum tag on differential cover to see if it has a posi.
My favorite model is the 1979 TA i could get one of those if i wanted but I'm not really into that style of TA. Also hes going to be doing all the body work and giving me all the replacement parts to make it nice so body work shouldn't cost me a penny, but starting off with a good body does sound like the best bet
They made more 79s than any other year. If it were me, I would be looking for a earlier year. A slab side would be best if he has one. It looks like he has some good builders in the pictures. I would run from the 79, it looks like a parts car.
I don't plan on selling the 79 once I'm done with it i just want it because i like the style of it not for the rarity. I am however gonna restore the 68 Firebird convertible he has in the back of his house once I'm done with my 79. but that's gonna be years in the making.
| Tags |
| 403, car, oldsmobile, snowflake, trans am |
| new at buying tools | ep50merc | Engine | 15 | 02-24-2007 08:44 AM |
| Buying New M-22 Super Case Trans | JimKramer | Transmission - Rearend | 3 | 02-01-2006 12:48 PM |
| Buying a used turbocharger | wutzu | Hotrodding Basics | 5 | 07-22-2005 02:19 PM |
| If you were buying? | HemmiGremmie | Hotrodders' Lounge | 1 | 05-27-2003 10:34 PM |
| Buying used pistons a good idea? also buying a used cam? | LoudMalibu | Engine | 5 | 03-20-2003 01:53 PM |
