bw transmission t10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2011, 02:01 PM
bw transmission t10
the trans has 10 spline input shaft and a 23 spline output shaft casting number is wf2623 i'am in need of a slip shaft for the tail shaft or what it comes out of.
Thanks for your help
Old 10-19-2011, 03:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Below are two PDF's for the BW T-10. Using them you will be able to ID the part you need. The files were originally submitted by member "AutoGear".
transmission id help excaliberprime Transmission - Rearend 3 02-28-2007 01:06 PM
What Transmission? Caesar_Mikey Transmission - Rearend 4 01-22-2006 03:51 PM
transmission jimmie powell Introduce Yourself 1 09-18-2004 10:54 PM
transmission TRSmet Transmission - Rearend 2 05-02-2004 11:26 PM
Which transmission to keep/run? wesblake Transmission - Rearend 6 03-13-2003 06:53 PM
