bypass MSD module and only use mag pickup? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2010, 02:42 AM
New Member
Hi
I have a MSD plug and run (8360) dissy and the module must be fried. Would it be possible to cut the mag pickup wires from the module then run them to a crane HI6 ignition using the mag pickup wire?
Old 01-10-2010, 07:59 AM
OLNOLAN's Avatar
Msd/crane Hi6
Maybe possible, provided you mag pickup is still good and not the actual problem to begin with. Here's the HI6 wiring instructions;
http://cranecams.com/pdf/90006000c.pdf
olnolan
Old 01-10-2010, 08:50 AM
New Member
I think it should work, the instructions show how to bypass a GM module so i think i should be able to do the same with the MSD. Just donít want to damage anything else while trying.
Old 01-11-2010, 02:51 AM
New Member
Stripped the dissy down only to find someone has allready bypassed the module. hooked up to the HI6 mag leads and its working well.
Old 01-11-2010, 06:33 AM
OLNOLAN's Avatar
A Haa
Good deal Sir, Hope you bought it dirt cheap and wasn't sold as good. olnolan
Old 01-11-2010, 08:13 AM
New Member
Yeah picked it up at a swap meet for $80au and thought there must be something wrong as i looked brand new and was still in packed in its box. Turned out to be an excellent deal.
