C-4 65 Mustang Tranny Rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2006, 06:48 PM
I have been mulling over the site for a couple hours now, but cannot seem to find the information I'm looking for. If it is on here then please just link me to it, but if not it would be a nice addition for archives!
I have a 1965 Mustang 289 auto ... if you couldn't tell from my name!
She has the original automatic transmission on her which, for what I came up with on this website, is most likely a C-4.
She slips into 2nd and lags into gear. I want to rip off the tranny and rebuild it myself so I know what the problem is and that I fixed (plus I don't really trust people to work on my baby). I have experience with a manual clutch replacement on a 95 maxima, but this is my only transmission work. I am mechanically inclined and don't think (with the help of a good manual) the rebuild would be a problem.
Where can I find information (rebuild kits, rebuild manual, information on my tranny) I also wanted to know how easy it is to throw in a stall converter as I want to make that engine 300+ hp eventually. Should I just wait to install the converter when I need it or would it save me alot of trouble just doing it now. Also, how would that affect Horsepower and engine performance since it is just a stock 289 Hipo right now?
Thanks again guys ... BTW LOVE THIS SITE!!!
Old 04-24-2006, 06:54 PM
Wiki Edits: 31
if you never done 1, best hire it done. you will need knowladge, patcience and a spec book. if it is a 3spd auto, it is a C4
Old 04-24-2006, 08:11 PM
Patience and Time I have, but knowledge and guidance I need. I would like to do this myself for two reasons:
1. To know how the damn thing works and is put together
2. To save some $$$$
It is a 3 speed auto so a C4 ... anyone have any info out there to help with a rebuild?
Old 04-24-2006, 09:47 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
These guys have kits, tech help line and manuals available for your tranny.
http://www.drivetrain.com/autotransoverhaulkits.html
Old 04-24-2006, 10:11 PM
Jmark's Avatar
I too am mechanically inclined and wanted to do my TH350 in my old truck. I got a good manual, and went for it. I also enlisted the help on occasion of a builder at Aamco that was nice enough to lend some advice and a few odd ball parts. I bought a full kit from Transtar here in Phoenix and went for it. It took a while, but it works like a dream, shifts great, doesn't leak and I learned a lot and for me, it was something I've always wanted to do. I say GO FOR IT!!!!
Mark
Old 04-25-2006, 12:44 AM
The C4 is one of the easiest American auto trannys to rebuild. I've rebuilt and modified at least half a dozen now. But you do need good guidance. The Haynes Ford Automatic Transmission Overhaul book is a good one and the one I learned with. There are others.
Here is what I consider the Mother Site for info on modifying the C4 for performance, that also offers identification and differences through the years:
http://www.fordmuscle.com/forums/c4-...ion2_9911.html
Old 04-25-2006, 12:15 PM
Thanks for the info so far guys!!! Keep it coming. I have another question about this rebuild after looking at another current thread along the same lines.
C4 rebuild using transtar
Originally Posted by red65mustang
agree with Chazmac,
1965 C4= 289/225hp/300ft/lbs at the flywheel = biggest motor
197X C4= behind a few 460's !!!! as a factory option!
need to know what year and which motor will it be plugged into
65' 289=5 bolt bell housing, 65' 200=5 bolt, pain the butt
It seems as though the early C4, as in the one I have, is not cut out for more than 250 hp or so, but eventually I want to throw headers on it and a couple other things to try to get it up over 300 hp. The most I would ever think about running on this car/engine would be 300-350 hp.
Should I just consider trying to pull a C4 from a newer car at some junkyard and rebuild this one as it seems it would be much better suited for my application, or keep mine??? I don't think my car is all number matching anyway and its my first rebuild/restomod so I'm just trying to learn while transforming what I have into a beauty of my own! HELP PLEASE!!!
Old 04-25-2006, 07:26 PM
There are a few things you can do to the old C4's like yours, such as install later valve bodies, but if you are going to build up power, I wouldn't chance it. The best C4's I've used have been the '71 up units (I'd include 1970 bit some of these had a 26/26 input shaft and parts are getting scarce). Note that your '65 engine has a 5 bolt bellhousing pattern (the bolts that connect the bellhousing to the block-used in '64 and '65) so a later tranny won't bolt to your original engine. Later engines use a 6 bolt pattern. I don't remember for sure (I haven't done it) but I believe you can use the 5 bolt bellhousing on 6 bolt trannys. If that's wrong someone here will correct me.
The later C4's are pretty stout, and if well built can handle a lot of HP. See that C4 site I mentioned.
Old 04-25-2006, 09:34 PM
65Stanger's Avatar
Check the water, check the oil
I've got a C4 in my Mustang, as well. =) I love the thing. Shifts beautifully, pulls good. I had the EXACT same problem as you, and I guess it happens every now and again. The shifter bracket/kickdown bracket has threads on the end that goes into the transmission, and after 40 years of cranking back and forth and being pulled at weird angles, especially if your kickdown is adjusted incorrectly, the threads crack. What happened was mine was in 1st gear, then it would shift HARD into second, and then slip all over the place. I tried everything. I eventually pulled it and rebuilt it with my boss's help (I work R&R at a tranny shop). If you need any help pulling her out, I can give you step by step instructions on doing it. Don't forget to disconnect the battery and all that stuff. Gotta pull the starter. It's a real easy pull compared to these new cars like 'Vettes and Mercedes. Basically make sure to check that bracket's threads. Also, you're gonna replace all your rubber seals and o-rings, right? =) You're going to be really happy with that transmission when it's all done, and you probably already love your 289. With a good overhaul kit and some clean guidance, your rebuild should go great. Also, are you thinking about replacing your torque converter? It's a good thing to do if you don't know for a fact that the one you have in there is in tip top shape.
Old 05-02-2006, 11:15 AM
Yes, I will probably just replace the torque converter! What would be the best way to go about getting a 7x C4 to replace mine? Also ... this project is on hold for 2-3 weeks becuase of money issues, but when I do it (whichever route I go) I will update it step by step with photos ... which section should I post that in?
Old 05-02-2006, 11:49 AM
hipo,
first de-code all of your car and check against the engine and tranny part #'s you have, so you know what you are dealing with
info for "how to" is in the knowledge base and on most mustang sites
unless your car was a museum piece till you bought it slim chance the motor and or the tranny are original,
post a new thread with the correct motor tranny info
Old 05-02-2006, 11:52 AM
PHATHOM's Avatar
My wife said no more hotrods..
Good luck
Replacing a clutch and rebuilding a trans are 2 completely different animals. I had one in my 66, loved it, and it is a bulletproof box. As for you problem, if it is not leaking, I would not yank it out untill I knew for a fact it had an internal failure issue. Change fluids, filter and modulator, and make the band adjustments. Then, if you are certain it is needed, take it to a PRO. It may cost a few hundred to have done, but it's money well spent versus opening it up and finding yourself as lost as working on a Klingon warp drive.
PS. : I am the second owner of my 66 and have had it for 30yrs. Before the recent project (351w upgrade), the c4 trans I had never required internal parts replaced.
Good luck
Old 05-02-2006, 12:04 PM
phantom, so far I do agree, fair to good chance it doesn't need to be pulled, just serviced
Old 05-02-2006, 12:47 PM
65Stanger's Avatar
You should post the pictures right here in this thread! I'll be looking forward to it.
'65 Mustang - Squeaky Stops 65Stanger Suspension - Brakes - Steering 2 01-29-2006 01:35 PM
65 Mustang hood ornament cybercat133 Body - Exterior 3 01-29-2006 09:50 AM
Will a 390 fit or work in a 73 Mustang..... onebadmerc Engine 4 12-08-2005 09:57 AM
65 mustang camber adjustment kit oldred Suspension - Brakes - Steering 1 01-05-2005 08:54 AM
what engine for a 65 mustang fastback duckhunter917 Engine 10 10-15-2002 02:38 PM
