C-4 Deep Pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 11:21 AM
C-4 Deep Pan
I recently purchased a deeper cast aluminum pan for my green-dot C-4. When I went to install it, I discovered the new pickup/screen was different from the original. There's no way to get it to match the original bolt pattern. Since the pan is just deeper, and the fluid level will come up to the original screen anyway, is it safe to use the original pickup/screen even if it doesn't extend deeper into the new pan?
Old 05-30-2005, 08:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
it will work fine. the filter bolts to the v-body as you know.
the fluid level remains the same , so all is good
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 03:46 PM
New Cam Install - Oil pan gasket info requested. Siggy_Freud Engine 5 12-17-2004 11:00 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
Deep Oil Pan Dipstick????? juveteach Engine 3 06-10-2003 07:00 AM
Tranny Pans...Stock or Deep Dish?? TheZaZ Engine 1 04-24-2003 03:04 PM
