C-4 front suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2007, 05:44 PM
Has anyone fabbed up their own front suspension using 1985 Corvette components ? Thank You. Little Joe
Old 11-09-2007, 06:07 PM
Notorious's Avatar
Hot rodder, not street rodder!
As the owner of a '95 C4 coupe, I can state that it would be relatively easy. '88-'96 varies a bit from the '84-'87 but are still basically the same. The entire front suspension with the exception of the forward sway bar brackets are self-contained to a cross-member. This could be cut out in it's entirety from a donor car. There are also after-market frames and frame sections/brackets, etc. available to utilize both the front and rear C4 suspensions. Plus, the components at both ends are all aluminum and can be polished to a high luster if desired.
Putting back together front suspension chirpn69 Suspension - Brakes - Steering 4 05-07-2006 12:48 PM
1978 Mustang front suspension marlene kit car Suspension - Brakes - Steering 8 03-14-2006 07:14 PM
Model A front suspension Alecigio Suspension - Brakes - Steering 11 08-24-2004 07:58 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
69 Nova front suspension, plz help onecoomofo Suspension - Brakes - Steering 2 02-01-2004 09:30 PM
