Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C-4 reverse problem
Old 10-20-2012, 10:46 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by dilligaf View Post
Put the transmission in reverse and wouldn't go anywhere. Put in forward gears and it worked. Retried reverse, nothing. This went on for 4 to 5 minutes. finally I cycled from first thru drive into neutral and then reverse and it went in with a clunk and seems to be fine now. What happened?
Old trans or rebuild?
You describe a molded rubber rear servo piston with hard rubber seal on it.
The piston is a steel unit with bonded - molded rubber seal on it. Seal gets hard and leaks.
