Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C-4 reverse problem
Old 10-21-2012, 05:12 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by dilligaf View Post
Rebuilt by the mustang shop in Phoenix.
You should re-check fluid level. If all forward gears work, then there is enough pressure for reverse.
If you have a weak 3rd gear, that would effect reverse too. The direct clutch and rear servo create reverse
