-   -   C-4 reverse problem (http://www.hotrodders.com/forum/c-4-reverse-problem-225204.html)
dilligaf 10-20-2012 11:56 AM
C-4 reverse problem
1 Attachment(s)
Put the transmission in reverse and wouldn't go anywhere. Put in forward gears and it worked. Retried reverse, nothing. This went on for 4 to 5 minutes. finally I cycled from first thru drive into neutral and then reverse and it went in with a clunk and seems to be fine now. What happened?
Crosley 10-20-2012 10:46 PM
Old trans or rebuild?
You describe a molded rubber rear servo piston with hard rubber seal on it.
The piston is a steel unit with bonded - molded rubber seal on it. Seal gets hard and leaks.
dilligaf 10-20-2012 10:52 PM
c 4
Rebuilt by the mustang shop in Phoenix.
Crosley 10-21-2012 06:12 AM
You should re-check fluid level. If all forward gears work, then there is enough pressure for reverse.
If you have a weak 3rd gear, that would effect reverse too. The direct clutch and rear servo create reverse
