C-4 reverse problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2012, 10:56 AM
dilligaf's Avatar
C-4 reverse problem
Put the transmission in reverse and wouldn't go anywhere. Put in forward gears and it worked. Retried reverse, nothing. This went on for 4 to 5 minutes. finally I cycled from first thru drive into neutral and then reverse and it went in with a clunk and seems to be fine now. What happened?
Old 10-20-2012, 09:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Old trans or rebuild?
You describe a molded rubber rear servo piston with hard rubber seal on it.
The piston is a steel unit with bonded - molded rubber seal on it. Seal gets hard and leaks.
Old 10-20-2012, 09:52 PM
dilligaf's Avatar
c 4
Rebuilt by the mustang shop in Phoenix.
Old 10-21-2012, 05:12 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You should re-check fluid level. If all forward gears work, then there is enough pressure for reverse.
If you have a weak 3rd gear, that would effect reverse too. The direct clutch and rear servo create reverse
powerglide reverse problem dirtrackin Transmission - Rearend 2 03-21-2010 12:32 PM
TH700R4 Reverse drum problem Calderone Transmission - Rearend 4 09-14-2008 01:18 PM
TH-350 reverse problem. Eric327 Transmission - Rearend 5 03-28-2006 06:08 PM
4l60-e no reverse problem ragman1 Transmission - Rearend 6 10-18-2004 04:06 PM
Anyone know about t-45 manual trans? reverse problem Jason Transmission - Rearend 1 06-15-2003 02:14 PM
