c-4 trans shift prob - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2010, 05:32 PM
i have a c-4 in a mustang and the problem i am having is that it shifts ok from first to second but from second to third i have to nail it to get to third. i cahanged the vac mod valve and it has improved some but when i get off the gas it goes quickly to second and then downshifts normally. is it internal,vacuum, or kickdown. i did switch carbs too.if you can help,thanks.
Old 09-19-2010, 05:44 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is this C4 high mileage or old? Recent rebuild?
did you retain the small pin for the modulator valve?
If the linkage to the carb from the trans is applying more leverage than needed, the trans may shift late
Old 09-19-2010, 06:15 PM
i am not sure about the pin. i took it in to have the valve replaced and a filter change done. not recently rebuilt but only has 57,635 miles on it.i had changed the carb because i thought it had a problem, but was wrong.was going to put it back on to see it it takes care of the problem. thought about adjusting the mod valve a little to see if that might help too.
4L60E Shift kit. GMCTRUCKS Transmission - Rearend 8 05-20-2012 04:22 PM
trans shift steve t Transmission - Rearend 1 09-17-2005 01:42 PM
dodge trans shift problem mottcobb Transmission - Rearend 1 08-15-2005 07:34 PM
First time trans rebuilder...need tips! 4 Jaw Chuck Transmission - Rearend 14 06-23-2004 03:29 PM
86 trans am lighting prob 350transam Electrical 0 06-01-2004 09:35 PM
