Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C 4 transmission
Old 12-10-2011, 08:38 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by dilligaf
Had to pull the engine to get to the torque converter. Couldn't pull transmission. When I pull the torque converter off will I lose fluid? I can't seem to get the converter to seat on the shaft any further than the first clunk. I have read that when it is seated properly you can't get your fingers in behind it. I can't come close to getting behind it.
If you pull the converter out fully, there is fluid that will run out if the trans was in recent use.
If you can use a straight edge tool to check how deep the converter is back from the front of the bell housing to see if there is room for the flexplate to fit.
