-   -   C 4 transmission (http://www.hotrodders.com/forum/c-4-transmission-210064.html)
dilligaf 12-10-2011 12:26 PM
C 4 transmission
Had to pull the engine to get to the torque converter. Couldn't pull transmission. When I pull the torque converter off will I lose fluid? I can't seem to get the converter to seat on the shaft any further than the first clunk. I have read that when it is seated properly you can't get your fingers in behind it. I can't come close to getting behind it.
Crosley 12-10-2011 08:38 PM
If you pull the converter out fully, there is fluid that will run out if the trans was in recent use.
If you can use a straight edge tool to check how deep the converter is back from the front of the bell housing to see if there is room for the flexplate to fit.
