Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - c-4 transmission info
Old 10-18-2002, 05:47 PM
jprowse00 jprowse00 is offline
New Member
yep , bolt pattern 's a problem , way i see it , if you'v got to get a bellhousing , and trade the valve body , you likely are better off starting with a later 70's trans .. lots of them around , and you don't have a miss-mash of parts when you'r done'l want to o-haul /resaeal either one .. my vote is a later model .. best of luck .jim prowse .
