As Long as your stock engine dosen't have the five bolt pattern it should work with the stock spacer plate and flex plate. If you don't have a six bolt block like the 351, you'll need a 351 or 302 spacer plate a six bolt bell housing for a later C4 and your flex plate, & torque converter, and you should be in business.
Papabird
