Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - c-4 transmission info
Old 10-20-2002, 02:59 PM
hotrodjoe hotrodjoe is offline
Hi. I have an early c-4 trans in my 26 T with a 300 HP 289. It works good with a shift kit. However, my car is lite,(2200 lbs) The 260 used a small (5 bolt) bell housing, while the 351 uses a larger (6 bolt) bell housing. I learned this thru experience, trying to do what you are. Good luck. joe
