C-4 or Tremec - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2007, 01:19 PM
1cleanmav!'s Avatar
C-4 or Tremec
i've got a C4 (automatic) siting behind my 250 i6, it snatches when i shift it; is this normal? also witch is better for my six, the C4 thats on it now or a Tremec?
Old 10-04-2007, 01:37 PM
Irelands child's Avatar
Not a clue as to what you mean by 'snatch'. And a C4 behind an I-6 is not necessarily the same as one from a V8
A well set up C4 will handle 350 or more horsepower and do it effortlessly.
To install a Tremec, it is expensive and fairly complicated - flywheel, clutch and its linkage, shifter, bell housing and possibly a different crossmember and driveshaft, then the cost of a transmission - and which Tremec do you want - and that's just the easy stuff.
Irelands child
I need a Borg Warner or Tremec classic_chevy_guy Transmission - Rearend 1 09-16-2004 10:00 AM
Wires and stuff on a tremec 3550???? slavboy1 Transmission - Rearend 3 06-24-2004 01:15 AM
pontiac 350 bb to tremec five speed 6speedwagon Transmission - Rearend 1 09-19-2003 01:32 AM
tremec or richmond gsmith Transmission - Rearend 2 08-11-2003 07:44 PM
Tremec in a street rod 37Ford Transmission - Rearend 1 08-11-2003 04:00 PM
