Looking for where to plug in the vacume line to my C 4 tranny. There is no tube or any kind of connection near the modulator. There is an open tube on the drivers side. Is that where the vacume line goes? Thank You
Is that a picture of the end of the modulator? There is no place to slip a hose on the modulator. The end of the modulator has a small screw. I can't find any hose fittings anywhere near the modulator. Help.......
Ok, I'm getting it. There was some grease and dirt around the hole, and a screw on the end of the nipple. I've never seen a vacume inlet with a screw in it. Anybody know what size vacume hose I need? Thanks Alot!
The screw is to adjust the part throttle shift points.
The vacuum actually goes through the hole in the middle of the screw.
I think the line is 1/4 metal line (use brake line) running up to the intake manifold, connected with short pieces of rubber line on each end.
I just want to thank everyone for all the help getting it through my thick head that the vacume line goes in the end of the modulator and yes, there can be a vacume intake with a screw in it. Thank You.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
