C 4 Vacume line - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2008, 12:48 PM
C 4 Vacume line
Looking for where to plug in the vacume line to my C 4 tranny. There is no tube or any kind of connection near the modulator. There is an open tube on the drivers side. Is that where the vacume line goes? Thank You
Old 11-22-2008, 01:16 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Photo post is the end of the vacuum modulator where the rubber hose atttaches.
this modulator needs full vacuum from the intake manifold.
the open tube you mention on the drivers side may be an early design breather tube. No vacuum goes there.
Old 11-22-2008, 01:44 PM
Ford C 4 vacume location
Is that a picture of the end of the modulator? There is no place to slip a hose on the modulator. The end of the modulator has a small screw. I can't find any hose fittings anywhere near the modulator. Help.......
Old 11-22-2008, 01:47 PM
If that picture was backed out a bit I could see where it's located. Thanks,,,,
Old 11-22-2008, 02:05 PM
look (just barely) above the tranny cross member support on the passenger side...
Old 11-22-2008, 02:07 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
this photo is a C4 modulator.
if you have a c4 trans , it is located on the passenger side of the main trans case at the rear - facing to the rear.
The mod either threads in or has a bracket with a bolt to hold the mod into the case
Old 11-22-2008, 02:21 PM
Here's 2 pics of the modulator. Does anyone know where the vacume tube is?
Old 11-22-2008, 02:23 PM
Ok, I'm getting it. There was some grease and dirt around the hole, and a screw on the end of the nipple. I've never seen a vacume inlet with a screw in it. Anybody know what size vacume hose I need? Thanks Alot!
Old 11-23-2008, 08:45 PM
The screw is to adjust the part throttle shift points.
The vacuum actually goes through the hole in the middle of the screw.
I think the line is 1/4 metal line (use brake line) running up to the intake manifold, connected with short pieces of rubber line on each end.
Old 11-24-2008, 09:18 PM
Ford C 4 Auto Vacume Line
I just want to thank everyone for all the help getting it through my thick head that the vacume line goes in the end of the modulator and yes, there can be a vacume intake with a screw in it. Thank You.
Anyone ever had a line lock fail and degrade braking? sizemoremk Suspension - Brakes - Steering 7 09-22-2006 03:13 PM
Can 2 line brake system be converted to 4? Neophyte Suspension - Brakes - Steering 8 03-07-2005 09:22 PM
vacume advance settings and "Run on problems" chrisgarrison Engine 9 01-29-2005 08:33 PM
where does the vacume lines connect? motormaster General Rodding Tech 2 09-23-2004 10:21 PM
