C-6 Bellhousing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 06:57 PM
FourSpeed460's Avatar
Ford 460 The only way to go!
C-6 Bellhousing
I am putting a big block 460 in a 84 3/4 ton pickup that previously had a diesel in it. My question is will the C-6 that has the bellhousing for a diesel bolt up to the 460? Any help would be greatly appreciated. Thanks Bryant
Old 01-22-2006, 07:01 PM
They look the same, but you will need a 460 case for the C6.
The engine dowel holes are way different and the bolt holes are not in the same location.
Get the trans rebuilt and recased for the 460. Most trans shops will be happy to get a good diesel case in return for the 460 case...
Old 01-22-2006, 07:03 PM
I am on a pretty tight budget is that big block case something easily found in a salvage yard?
Old 01-22-2006, 07:08 PM
Might be, but you HAVE to disassemble trasn to get it. Salvage yard C6 from 460 might be more than a little tired.
Rebuilt trans and stock type converter should $500-$600....
Think about it.
Installing tired trans to just pull it out later...where is the wisdom??
Old 01-22-2006, 07:14 PM
The 84 that has the C-6 in it was parked about 1993 could the trans be worn out bad enough that it needs rebuilding? My other option is the T-19 that is in the donor vehicle.
Old 01-22-2006, 07:23 PM
The 84 trans fits the diesel only...
The stick fits the 460...
If you want an automatic you have to rebuild the 84 trans with a 460 trans case
Old 01-22-2006, 07:30 PM
Alright Thanks for the information Ill have to check into prices and then figure something out
which bellhousing nick62877 Transmission - Rearend 7 06-29-2005 07:02 PM
Lakewood bellhousing shagginwagonvic Engine 6 02-13-2005 04:51 PM
Bellhousing Question JamesRS Transmission - Rearend 7 11-15-2004 09:06 AM
bellhousing fordriffey Transmission - Rearend 1 01-06-2003 03:47 PM
engine bolt hole to bellhousing is broken, is it ok? 66StangBoy Engine 6 11-06-2002 05:25 PM
