c-6 bolt patterns? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2009, 09:09 PM
Last journal entry: Well, about that mustang...
c-6 bolt patterns?
i just picked up a c-6 transmission... i just tried to line it up to my 460 c.i.d and the bolt pattern is completely different. i dont some snooping around on here and seen a post where someone mentioned that there are 2 different bolt patterns for these d**n things?!?! is there an adapter or a way i can switch bellhousings to match the bolt pattern on my engine? thanks
Old 04-15-2009, 09:42 PM
There's actually 3 patterns, small block, 385 series, and FEs... None of which interchange. Since the C6's bellhousing and case are a single cast unit, they can not be swapped between different engine families like a C4 or FMX can, you just have to have the right one for your motor sorry to say. The small block pattern is easy to tell, it's small... The 385 series is sorta tall and egg shaped, I'd say upwards of 30 inches, where the FE pattern is almost a circle.
Old 04-16-2009, 12:29 AM
Wiki Edits: 85
As stated in previous post, you can't switch bells.
The 460 takes a high top bell about 7" between top bolts. The small block is 5-1/8" between top bolts. The FE bell is almost perfectly round.
And there are 3 more bell types for C6s. Diesel (same as 460 but with cutout on bottom of bell), Lincoln 460 (Pointed top), and Lincoln 462 (Pointed top).
More information here: http://www.crankshaftcoalition.com/w...Identification
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Engine build question here n-gin Engine 10 06-11-2008 06:04 AM
ARe BBC and SBC transmission bolt patterns the same? brian12c Transmission - Rearend 1 06-18-2006 05:33 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
bolt patterns 49olds Suspension - Brakes - Steering 3 04-21-2004 07:11 AM
