C-6 Problem...... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2007, 07:45 PM
C-6 Problem......
I have a van with a C-6 tranny and I'm having problems with the way it shifts. What's wrong with it if it won't shift into drive until it reaches 45 mph? I'm guessing a sticky valve. I took it for a drive last night and it wouldn't shift into drive at all. Any suggestions?
Old 06-06-2007, 01:40 PM
c-6 problems
Have you checked vacuum at the modulator? As in, is there any.
You should feel a rather strong tug on your finger against the vacuum hose, engine running, of course.
If you have a gauge, thats even better. Look for about 18" of vacuum.
Old 06-06-2007, 05:01 PM
Not yet but I was planning on checking that this weekend when I get some time. I did have a module go to #$^% on me once.
Old 06-18-2007, 06:13 PM
woodz428's Avatar
Troll Hunter
A bad kick down adjustment could give you a poor shift to. A bad modulator should make it shift "hard" when it shifts.
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Wiring problem is driving me crazy pmeisel Electrical 7 07-12-2005 07:45 PM
Problem batch loading larger images cboy Hotrodders Site Suggestions and Help 10 03-23-2005 08:26 PM
*&%##*^#!! starter problem solved!!!! 85 vette Engine 12 02-22-2005 08:12 AM
