Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C-6 shifting issues
Old 04-20-2013, 07:29 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
drive it a while. Check shift linkage adjustment
Make sure the vacuum source is hooked to direct manifold vacuum on intake, not spliced together with other hoses.
Make sure the TV linkage from carb down to the trans is operational and free moving
