C-6 shifting issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2013, 11:42 PM
junkyardjeff's Avatar
C-6 shifting issues
I have a late 70s C-6 in my 66 F250 that sat for a few years before being installed in the 66,when I finally got the truck drivable I noticed it would not down shift into first at a light but it started to go into first now but is going from first to third and skipping second. It will manually shift fine so I am thinking that sitting for about 3 years without fluid and then 4 years while I got the body work done something is sticking,right now I am trying to get some carb/fuel delivery issues figured out I hope to put some miles on it to see if what ever is sticking will work loose. Its been so long since I took it out of the donor truck but thought it shifted like it should but I drove it home from buying it and then it sat.
Old 04-20-2013, 08:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
drive it a while. Check shift linkage adjustment
Make sure the vacuum source is hooked to direct manifold vacuum on intake, not spliced together with other hoses.
Make sure the TV linkage from carb down to the trans is operational and free moving
Old 04-20-2013, 07:37 PM
Took it for a drive today and I think its shifting very fast as I was able to feel all gears when taking off very slow.
Old 04-21-2013, 11:27 AM
pricesgarages's Avatar
the servo is bad the piston gets hard replace it you should be fine
T-400 2-3 shifting issues ducrider123 Transmission - Rearend 2 03-08-2012 12:45 PM
700r4 shifting issues nytetrain Transmission - Rearend 1 02-13-2012 07:26 PM
4l60e shifting issues jtalb Transmission - Rearend 3 12-06-2011 09:07 AM
T-400 Shifting Issues cm113 Transmission - Rearend 4 10-26-2009 06:04 PM
th 350 shifting issues frankenstang57 Transmission - Rearend 2 04-20-2005 04:56 PM
