c 6 trans ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 09:36 PM
c 6 trans ?
I got a.Trans for a 351W .?is will this bolt up to a 460 Ford or is bellhousing different? Not sire on these 385engines yet plan on building a 557.
Old 03-31-2012, 10:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
As I recall the 351 M block is the same as the BB 460 engine, 351W uses small block style pattern
Old 03-31-2012, 10:38 PM
Wiki Edits: 85
351W bolt pattern is different than the 460 bolt pattern.
Old 03-31-2012, 10:44 PM
Thanks.will be looking for.a.Trans one out of a truck would be the best more clutches ? It will be professionaly rebuilt
Old 04-01-2012, 07:12 AM
The ribbed case C6 is preferred for strength but not absolutely necessary. Gotta be careful on sourcing from a truck or van. I believe they use a longer tailshaft than a passenger car C6. Lincoln's same deal.
Old 04-01-2012, 07:20 AM
Thanks didn't know that
Old 04-01-2012, 09:17 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2
Cole
Old 04-01-2012, 10:18 AM
Old 04-03-2012, 05:05 AM
Wiki Edits: 85
Truck C6s with a slip yoke had 13-3/4" tails, same as most passenger cars.
Old 05-23-2013, 10:28 AM
I think it will be better to go with a powerglide over the C6 on the 86 notch with the 557.correct? got 4.30s. 9inch.33 spline? I was told when I brought thr car do they have 33 splines? I go 35's on my other 9inch. tires are 32 tall, ,thanks.
changing a Aod trans. over to a c6 trans. thndrchkn Transmission - Rearend 1 11-08-2011 07:53 PM
trans swap, 400 trans in 83 elcamino? renagade Transmission - Rearend 2 10-07-2011 10:45 AM
1992 gmc trans shot, will 1986 trans fit? Jamesace Transmission - Rearend 4 05-06-2010 03:42 AM
Synthetic Trans Fluid Mixed With Regular Trans Fluid smokey626 Transmission - Rearend 1 06-14-2009 02:33 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 12:14 PM
