Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 05-24-2008, 05:07 PM
1980camaro 1980camaro is offline
C.B. Radio help
I want to put a C.B. in my camaro but I dont want a big *** whip on the back of my deck lid. is there any way to get decent reception without have an outside antenna?
Old 05-24-2008, 05:38 PM
matt167 matt167 is offline
 matt167's barnstar
Wiki Edits: 19
re: C.B. Radio help
put it on the frame
Old 05-24-2008, 06:21 PM
kc0kfg's Avatar
kc0kfg kc0kfg is offline
kc0kfg
re: c.b.
Well sorry to tell you there is no free lunch when it comes to 11m band (c.b.)
You could throw 1500w into some rinky antenna or some fad that uses the fm antenna and I would still get out better with a good wilson and 5w, while you dont need a 102' whip on the back, a good bottom loaded willson wilson 5000 is the ticket.
They can be mounted with a trunk lip mount or a magnet mount but be warned either may mark up the finish .
If I had to pick I would say a wilson 500 using a magnet mount on the trunk,(center of the roof would even be better but I understand) leave some slack in the line and remove it when not in use.
A couple of other quick tips 1. tune the antenna or find some one who knows how (some one in a ham radio club could help)
2.DO NOT cut or coil the coax on the wilson.
You should be able to find a wilson 5000 mag mount at most large truck stops or better yet online just make sure its for 10-11m band.
Brian kc0kfg
Old 05-24-2008, 06:33 PM
poncho62's Avatar
poncho62 poncho62 is online now
Moderator
 poncho62's barnstar
Wiki Edits: 4
re: C.B. Radio help
I have a portable CB that I keep in my motorhome.........Its like a big walkie talkie.......has a built in antenna..........It works OK in traffic jams........I can pick up those truck drivers swearing to beat the band....................
Old 05-26-2008, 09:26 PM
jimfulco jimfulco is offline
re: C.B. Radio help
I used to use a 24" top-loaded whip on a magnet mount just behind the windshield. It lived in the trunk when not in use. Worked pretty well, not as well as a full-sized antenna, but much better than when I tried it in the back seat with a small window-screen for a ground plane.
Old 05-27-2008, 05:21 PM
SteveU SteveU is offline
re: C.B. Radio help
Antenna makes all the difference when it comes to radio. I'd get a bottom loaded whip antenna which will get you out 8-10 mi depending on the conditions/terrain. The gutter mount antennas don't work as well but are more compact. I had a mobile moonraker on the trunk of my 79 which didn't look bad at all.
Old 05-27-2008, 08:15 PM
Cape Cod Bob's Avatar
Cape Cod Bob Cape Cod Bob is offline
re: C.B. Radio help
They used to make an ant. that went in place of your stock one and ran both sets.
Old 05-27-2008, 08:31 PM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
re: C.B. Radio help
And they sucked.
Old 05-28-2008, 03:48 AM
poncho62's Avatar
Moderator
 poncho62's barnstar
Wiki Edits: 4
re: C.B. Radio help
AMC had a factory setup in the early 70s.........No, didn't work real well, but no gaudy antennae.
Old 05-28-2008, 08:46 PM
TMF TMF is offline
re: C.B. Radio help
Originally Posted by Greg T
And they sucked.
LOL!!!!
Old 05-28-2008, 10:03 PM
GMCTRUCKS's Avatar
GMCTRUCKS GMCTRUCKS is offline
Cb
I have one that I want to place on my truck just haven't got around to it im going to use a magnetic one.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "C.B. Radio help"
1956 Ford F100 Radio djboen General Rodding Tech 4 05-18-2008 06:06 PM
AM Radio... BigBlockBabe Interior 16 04-06-2008 07:50 AM
Old radio personalities and some help Halloweenking Hotrodders' Lounge 17 06-03-2007 11:49 PM
Radio Static bluesman123 Electrical 5 05-17-2004 09:31 AM
Radio Station Update Halloweenking Hotrodders' Lounge 8 07-28-2002 09:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
